Hybrid and multi‑cloud environments didn’t break operations—they simply outpaced the human ability to manage them. Gartner predicts that 90% of organizations will adopt a hybrid cloud approach through 2027, confirming that multi-vendor estates are now the permanent operating model. Yet, as environments grow more distributed, a “Complexity Gap” has emerged.
According to the 2025 SolarWinds IT Trends Report, while many teams feel resilient, they are actually struggling with hidden fragility caused by fragmented signals. Engineers today spend as much time reconstructing manual context during an incident as they do fixing the actual problem. The bottleneck in modern IT is no longer compute or storage; it’s cognition. In fragmented estates, signals arrive disconnected and context must be rebuilt manually. The answer isn’t “more data, it is shared context followed by Agentic AI that turns understanding into safe, repeatable action.
Explore the Blueprint: This shift is explored in the Unified. Proactive. Automated. eBook —a practical guide to reducing cognitive load and acting earlier with confidence.
TL:DR Reducing Cognitive Load in IT
Unified Context First: Unifying IT systems so teams operate from a consistent context is the baseline for Intelligent Operations
Proactive Understanding: The goal is earlier understanding, not just earlier alerts that add to the noise
Safe Automation: Use a Human-in-the-Loop model to close the loop safely without losing oversight.
What Is Agentic AI in IT Operations?
Agentic AI refers to systems that serve as a “digital teammate”. Unlike standard Generative AI that only suggests code, Agentic AI performs. It can analyze telemetry, reason within defined policies, and execute multi-step tasks like collecting diagnostics or triggering rollbacks.
In a hybrid environment, these agents act as decision support, surfacing relationships and prioritizing responses so humans can focus on judgment rather than manual stitching
5 Steps to Implementing Agentic AI (Context-First)
To move from reactive monitoring to intelligent operations, teams must follow a deliberate path:
- Unify Context: Map dependencies and topology across hybrid edges to create a “shared baseline reality”.
- Interpret Changes: Identify “what changed” (deployments, config drift) to shorten the distance between signal and understanding.
- Recommend and Validate: The Agent proposes a “play” and checks it against policy boundaries.
- Human-in-the-Loop Approval: An engineer reviews the AI’s hypothesis and approves the action for moderate-impact tasks.
- Execute & Verify: The Agent performs the task, verifies recovery against SLOs, and records a full audit trail.
Guardrails: Keeping Agentic AI Safe
Mature teams treat AI as a teammate, not a risk, by ensuring every action is explainable, auditable, and reversible. To do this, SolarWinds follows an AI by Design philosophy that prioritizes accountability and transparency.
Using the Human-in-the-Loop Framework, you can categorize operational tasks into four distinct Autonomy Zones based on risk and frequency:
Full Autonomy: Routine, low-risk, and high-frequency tasks where the agent acts independently (e.g., initial log collection).
Guided Autonomy: Moderate-impact actions that require a “One-Click” human approval before execution.
Human-Led: High-risk or high-impact scenarios where AI provides the context, but a human must stay firmly “in the loop” to make the final decision.
No Autonomy: Critical or irreversible tasks requiring purely manual intervention.
By applying the Undo, Audit, and Threshold tests from the framework, teams can earn trust incrementally, moving tasks toward higher autonomy only after they have proven reliable.
Best Practices for Hybrid Operations
- Consolidate Understanding, Not Tools: You don’t need onetool; you need one shared story across your stack.
- Shift from Detection to Decision Support: Systems should help you interpret impact and prioritize response, not just fire alerts.
- Automate the Repetitive, Not the Risky: Start with enrichment and routing to get issues to the right owner faster.
- Design for Auditability: Every AI decision must leave a “paper trail” to build operational trust
Where to Begin Without Adding Complexity
Intelligent operations mature gradually. Start where friction is highest—recurring incidents that drain time or services that escalate quickly.
Map Your Autonomy Zones
Download the Framework for Human-in-the-Loop Decision Making to safely categorize your tasks and reduce repetitive effort without losing control.
Agentic AI is not The Same as Generative AI or Ops
Generative tools explain; agentic systems act—within guardrails. In operations, that means correlating signals, proposing the next step, and (when appropriate) executing it with full auditability
You don’t need to consolidate all tools before you start.
What you need is shared context, not a forced migration. Unify relationships and dependencies across your estate, so every signal lines up behind the same story. Observability provides that substrate.
Yes, agentic AI can reduce alert fatigue—if context comes first.
When signals are correlated to incidents and “what changed” is made explicit, AI can suppress duplicates, cluster related events, and elevate what truly matters, earlier.
Where should automation begin?
Start in the autonomy zone with low risk, high frequency actions (diagnostics, restarts, cache flushes). Keep human approvals for higher impact moves. Expand autonomy only after passing the Undo/Audit/Threshold tests.
How does this improve operational resilience? By shrinking time to understanding and standardizing responses, organizations handle more disruption with less effort—sustaining service quality across hybrid and multi-cloud change.
Conclusion
Hybrid and multi‑cloud are the default reality. Thriving in this environment isn’t about more tools, but about context first, understanding earlier, and automation with guardrails. Agentic AI delivers its greatest value when it focuses on the “thinking work” that drains human time, allowing your team to scale without burning out.
Unified. Proactive. Automated.: A Blueprint for Hybrid Operations
Modern IT environments are more fragile than most organizations realize. Get the eBook to learn how to bridge the cognition gap and implement intelligent operations safely
The post How Agentic AI Powers Hybrid and Multi‑Cloud Operations appeared first on SolarWinds Blog.
